Series format "panel".
Hello all,
Is it possible to embed the series format panel into another dialog?
What I want to so is have the panel below (Format, Point, General and Marks (I don't want "data source")) in my own dialog so a user can format the series.
Thanks in advance,
Tony.
Thanks in advance,
Tony.
- Series panel contents.jpg (30.22 KiB) Viewed 24961 times
Re: Series format "panel".
Hi Tony,
Have you seen the demo at All Features\Welcome !\Components\Chart Editor\Chart Editor dialog?
As you'll see, you can hide some tabs of the Chart Editor.
Yes, I use the chart editor already.
But I would like to be able to just give the user formatting options for a particular series (so not even let them select the series). All I really want them to see is "format", "point", "general" and "marks", is there any way of doing this?
So far I've duplicated the functionality in my own dialog, but if it can be done already I will use that.
Tony.
Tony.
Another related question.
How do I go about hiding pages from the embedded dialog? The only source code for it in the feature demo is
Private Sub Form_Load()
ChartEditorPanel1.Chart = TChart1
TChart1.Series(0).FillSampleValues 10
Combo1.ListIndex = 0
Combo2.ListIndex = 0
End Sub
And the "Tabs Position"/"Tabs Style" do not seem to do anything.
What I'm trying to do is display this, hide everything apart from the series tab, and draw a window over the part I do not want the user to see.
Tony.
End Sub
Tony.
Hi Tony,
I've added it to the wish list to be implemented in future releases (TA05015048). In the meanwhile I'm afraid you should create your custom dialog adding the functionalities you want to it.TonyVSUK wrote:But I would like to be able to just give the user formatting options for a particular series (so not even let them select the series). All I really want them to see is "format", "point", "general" and "marks", is there any way of doing this?
You are right. The properties bellow don't exist in TeeChart ActiveX. They exist and work in TeeChart VCL, they have to be translated to the AX version. I've addie it to the wish list to be implemented in future releases (TA05015049).TonyVSUK wrote:And the "Tabs Position"/"Tabs Style" do not seem to do anything.
Are either of these in the 2010 beta?Yeray wrote:I've added it to the wish list to be implemented in future releases (TA05015048). In the meanwhile I'm afraid you should create your custom dialog adding the functionalities you want to it.
Hi TonyVSUK,
I'm afraid they haven't been implemented yet.
Any chance of them making the final release?
Only asking as it will save me possibly days of work replicating the functionality.
Hi TonyVSUK,
I'm afraid that these items hasn't been implemented yet. I've incremented their priority.
Has this been implemented yet?
I'm back actively improving the chart capability of my app, and wondering if it's time to move to an alternative chart component.
Hello Tony,
TA05015048: We are trying to implement it right now. It will probably be included in the next maintenance release that should be published imminently.
TA05015049: Already implemented. It will be included in the next maintenance release.
Is this the new CChartEditorPanel class?
I'm not sure how to use it. I've created a CChartEditorPanel class, but there are no create/show window methods available.
I'm using Microsoft Visual Studio 2008.
Hi Tony,
No, you should use ShowInEditor property, for example:
axTChart1.AddSeries(TeeChart.ESeriesClass.scLine);
axTChart1.Series(0).FillSampleValues();
axTChart1.Series(1).FillSampleValues();
axTChart1.Series(0).ShowInEditor = false;
axChartEditorPanel1.ChartLink = axTChart1.ChartLink;
The original question was relating to a series format panel. That's what I'm looking for here.
Can I do it?
Can I do it?
