We've tested also on other machines and we still get the problem.
I attached a picture with the stack trace of the dump file from our demo project crash.
TeeChart2014.0.0.2 in Japanese system
Re: TeeChart2014.0.0.2 in Japanese system
- StackTraceGDIPlussCrash.PNG (69.57 KiB) Viewed 12071 times
The cause of the problem has been identified and we are working on a fix. It's taking some time to identify a working solution as what seems to be required on Japanese systems is contradictory to what is suitable on other systems. We'll make a test version available when we get to a viable proposal.
I'm sending a new pre-release version of the ocx to the mail account you have registered in this forum.
Thanks, it's working.
Should we use the sent ActiveX control or there will be another release soon?
If that pre-release ocx we sent you works fine for you, there's no objection on our part for you to use it.
Good news! I'm glad to hear that.Micro wrote:Thanks, it's working.
There was a maintenance release recently published. I'm afraid I can't tell you when the next one will be published.Micro wrote:Should we use the sent ActiveX control or there will be another release soon?
