Axes label cannot display if all data <+/-1e-12, auto scale
XY Graph control developed by Teechart 2013 ocx orTeechart 2015 ocx,
If all data values in range less than +/-1e-12, graph in auto-scale, the Axis labels can't be displayed. The attached report has been shown the issue.
For semiconductor industry, the +/-1e-13 or even less values is kind of noise, leakage data, it's very common.
Our clients are facing label display issue to view their data trend, and it's very critical functionality.
Because of this bug. Our clients rejects acceptance, we have problem to get payment from clients. Please kindly help & support this bug fix.
- AxisLabelDisplayProblem.zip
- defect report
- (323.53 KiB) Downloaded 1107 times
Re: Axes label cannot display if all data <+/-1e-12, auto scale
uploaded file: Eng_Sweep_AlgoLeakTest_151218_112931.xls for axis labels displaying expectation.
- Eng_Sweep_AlgoLeakTest_151218_112931.zip
- (13.57 KiB) Downloaded 1106 times
You could try using custom labels. Ie:
With TChart1.Axis.Left
.Labels.Clear
tmp = .Maximum
If .Increment <> 0 Then
diff = .Increment
Else
diff = (.Maximum - .Minimum) / 10
End If
While (tmp > Minimum)
.Labels.Add tmp, Format$(tmp, TChart1.Axis.Left.Labels.ValueFormat)
tmp = tmp - diff
Wend
End With
Yeray, Thank you for quick response,
We followed your instruction to use custom label.
We got labels we want successfully in TeeChart 2013 OCX version, apply the same methodology in TeeChart 2015 OCX, custom labels can be displayed but all of them went to 1 lines, overlapped to each. Would you please advice us solution for it.
- CustomLabel_Data.zip
- (51.24 KiB) Downloaded 1099 times
I'm trying to reproduce the problem with the project below and TeeChart v2015.0.0.3 and it seems to work fine Could you please modify it so we can run it as-is to reproduce the problem here?
Yeray,
We uploaded the sample code: TChartCustomLabel.zip, after unzip the file. Please first read this file: TChartCustomLabel_ReadMe.png.
Thank you.
Thank you.
- TChartCustomLabel.zip
- (453.14 KiB) Downloaded 1091 times
I'm afraid that's a known limitation. See this reply:
http://www.teechart.net/support/viewtop ... 890#p24890
So, in ActiveX you should modify the values in your series to fill in the supported range and then use custom labels to represent the original values instead of the modified.
Yeray,
We like to say is: use same sample with custom labels code on teechart2013 ocx, labels can be fully displayed successfully, but teechart 2015 ocx cannot fully display. We have no clue about two ocx version return different results. We really hope there is just a setting or one line code add can fix problem on teechart2015.
Please unzip the file: TChartCustomLabel_v2013.zip and first check this file : TChart2015_LabelsOverlayIssue.xls.
Thank you.
Thank you.
- TChartCustomLabel_v2013.zip
- (391.55 KiB) Downloaded 1074 times
I've added a test project and screenshots testing your values against different TeeChart versions here:
http://bugs.teechart.net/show_bug.cgi?id=1390
Take a look at this workaround. It's written in delphi but you shouldn't find too much problems on translating it.
It consists of changing the YValues of the series to have values in a more regular range. Then you can use custom labels doing the inverse operation:
procedure FixLabels(chart: TChart);
const t=1E+12;
var i: Integer;
tmpValue, tmpDiff: double;
with chart do
with Series[0] do
for i:=0 to Count-1 do
YValue[i]:=YValue[i]*t;
Draw;
with Axes.Left do
tmpDiff:=(Maximum - Minimum) / 8;
tmpValue:=Minimum;
Items.Clear;
while (tmpValue<=Axes.Left.Maximum) do
Items.Add(tmpValue, FormatFloat(AxisValuesFormat, tmpValue/t));
tmpValue:=tmpValue+tmpDiff;
