TeeChart with ColorGrid series crashes when mouse is moved
Latest TeeChart2015.ocx: crash, latest TeeChart2014.ocx: works fine. Example program with source code and .tee file included which can be used to reproduce and debug the problem.
- ColorGridGraph.zip
- .tee file. Copy this file to the .exe folder.
- (491.96 KiB) Downloaded 991 times
- TeeTest.zip
- Source code to reproduce the crash. Loads .tee file.
- (88.11 KiB) Downloaded 946 times
Re: TeeChart with ColorGrid series crashes when mouse is moved
We could reproduce the problem here with your .tee file. Thanks for reporting it.
While we investigate the root of the problem, we've seen disabling the mouse events at least stops this error:
m_pChart1->SetEnabled(false);
Unfortunately disabling chart is not an option as we use mouse notifications from chart in our implementation.
We could reproduce the problem also in VCL thanks to your tee file so I added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1456
