Problem with Access Anchor Control
PhG47
Post by PhG47 » Thu Apr 06, 2017 6:16 am
The size of "TeeChart 2017 Pro ActiveX" do not adapt themselves correctly when the control has to follow the resizing of a form Access 2010,2013,2016.
- Click to select the control TeeChart on Access Form
- Set the properties: horizontal and Vertical Anchor = Both
- Run Access Form
The problem is visible in the screen.
Philippe
Re: Problem with Access Anchor Control
Post by Yeray » Fri Apr 07, 2017 3:18 pm
Hello Philippe,
I could reproduce the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1840
Thanks for reporting it.
