I have the Std Version and have used two charts on the screen for the user. 1 bar chart with 2 series and a pie chart with 1 series. Is there a way to have both charts print on one page?Regarding the layout, I see two options:
- You can create two charts. One on the top with two TBarSeries, and one on the bottom with a TPieSeries.
- You can create a chart with a TSubChartTool. The main chart could contain the two TBarSeries and the Chart in the SubChartTool could contain the TPieSeries.
Printing 2 charts on one page
Re: Printing 2 charts on one page
Have you tried to follow the "Print previewing several Charts on one page" instructions in the "Tutorial 14 - Printing Charts" in the online documentation?
Not as easy as that, but extracting part of the code from the Pro unit "PreviewPanel":Yeray wrote:Hello,
uses FMX.Printer, FMXTee.Canvas;
var PaperRect: TRect;
PaperColor: TColor;
Procedure CalcPaperRectangles;
var
PrinterWidth : TCoordinate;
PrinterHeight : TCoordinate;
procedure SetScreenSize;
var P : TPoint;
P:=TeeGetScreenSize;
PrinterWidth:=P.X;
PrinterHeight:=P.Y;
Const Margin=5;
Var tmpClientWidth,
tmpClientHeight,
tmpWidth,
tmpHeight : TCoordinate;
Printer.Orientation:=TPrinterOrientation.poPortrait;
{$IFDEF ANDROID}
SetScreenSize;
{$ELSE}
try
PrinterWidth :=Printer.PageWidth;
PrinterHeight:=Printer.PageHeight;
except
on EPrinter do
SetScreenSize;
{$ENDIF}
tmpClientWidth:=Width;
tmpClientHeight:=Height;
if (tmpClientWidth*PrinterHeight)>(tmpClientHeight*PrinterWidth) then
Begin
tmpHeight:=tmpClientHeight-Round(tmpClientHeight/Margin);
PaperRect.Top:=Round(tmpClientHeight/(2*Margin));
PaperRect.Bottom:=PaperRect.Top+tmpHeight;
if PrinterHeight>0 then
tmpWidth:=(tmpHeight*PrinterWidth / PrinterHeight)
tmpWidth:=tmpClientWidth;
PaperRect.Left:=(tmpClientWidth-tmpWidth)*0.5;
PaperRect.Right:=PaperRect.Left+tmpWidth;
end
Begin
tmpWidth:=tmpClientWidth-Round(tmpClientWidth/Margin);
PaperRect.Left:=Round(tmpClientWidth/(2*Margin));
if PrinterWidth>0 then
tmpHeight:=(tmpWidth*PrinterHeight / PrinterWidth)
tmpHeight:=tmpClientHeight;
PaperRect.Top:=(tmpClientHeight-tmpHeight) *0.5;
Function CalcImagePrintMargins(const APanel:TCustomTeePanel):TRect;
var PaperWidth : Integer;
PaperHeight : Integer;
RectSize(PaperRect,PaperWidth,PaperHeight);
if Assigned(APanel) then
with APanel do
if PrintProportional then
PrintMargins:=CalcProportionalMargins;
result:=APanel.PrintMargins
end
else result:=TeeRect(15,15,15,15);
With result do
Left :=PaperRect.Left +(Left *PaperWidth *0.01);
Right :=PaperRect.Right -(Right *PaperWidth *0.01);
Top :=PaperRect.Top +(Top *PaperHeight *0.01);
Bottom:=PaperRect.Bottom-(Bottom*PaperHeight *0.01);
Function GetPrintingBitmap(const APanel:TCustomTeePanel):TBitmap;
var tmpR : TRect;
WinWidth : Integer;
WinHeight : Integer;
tmpW : Integer;
tmpH : Integer;
tmpWidth : TCoordinate;
APanel.Printing:=True;
try
With APanel.GetRectangle do
tmpWidth:=Right-Left;
tmpHeight:=Bottom-Top;
tmpR:=CalcImagePrintMargins(APanel);
APanel.CalcMetaBounds(tmpR,TeeRect(tmpWidth,tmpHeight),WinWidth,WinHeight,tmpW,tmpH);
result:=APanel.TeeCreateBitmap(PaperColor,TeeRect(WinWidth,WinHeight),TeePixelFormat);
finally
APanel.Printing:=False;
Procedure SendAsBitmap(const APanel:TCustomTeePanel; const ACanvas:TCanvas; Const R:TRect);
var tmpBitmap : TBitmap;
tmpBitmap:=GetPrintingBitmap(APanel);
try
ACanvas.DrawBitmap(tmpBitmap, TeeRect(tmpBitmap.Width,tmpBitmap.Height),
R,1);
finally
tmpBitmap.Free;
PaperColor:=TAlphaColors.White;
Printer.BeginDoc;
try
SendAsBitmap(Chart1,Printer.Canvas,Chart1.ChartPrintRect);
SendAsBitmap(Chart2,Printer.Canvas,Chart2.ChartPrintRect);
Printer.EndDoc;
except
on Exception do
Printer.Abort;
if Printer.Printing then
Printer.EndDoc;
Raise;
Chart1.PrintProportional:=False;
Chart2.PrintProportional:=False;
Chart1.PrintMargins:=Rect(2,2,2,50);
Chart2.PrintMargins:=Rect(2,50,2,2);
Thanks for this code. But my double chart will show only one chart when either chart is clicked or drilled-down.
- If a user clicks on the bar chart, I am going to set the Bar chart and the splitter visible := false and use only the pie chart.
- In some cases if a user clicks on the Pie chart I will do the same thing, leaving only the pie chart
What would I need to alter when printing just the pie chart?procedure TForm1.FormCreate(Sender: TObject);
Hello
To print only one chart you can just:realsol wrote:What would I need to alter when printing just the pie chart?
Chart2.Print;
I knew it was a simple answer. I'll move the code from the OnCreate to my printer button and use it only if I am printing 2 reports and use Chart.Print when printing one.
