Peter Carr
![Newbie Newbie](./images/ranks/1star.gif)
Post
by Peter Carr » Tue May 30, 2017 7:16 pm
I can enter a custom axis label using E-notation. For example, 1.23E3 for 1230. I attempted to use superscript notation by setting
Chart1.LeftAxis.LabelsExponent:=True;
Chart1.BottomAxis.LabelsExponent:=True;
But, in the example above, this gives 1.23[super]3[/super] where I was expecting 1.23 x 10[super]3[/super].
"En" seems to be interpreted by Teechart as "power of n" whereas in standard E-notation it means "times 10 to the power of n". This seems to me to be a bug rather than a feature.
Is there a workaround?
![Site Admin Site Admin](./images/ranks/6stars.gif)
Post
by Sandra » Wed May 31, 2017 9:23 am
Hello Peter,
If you set true the AxisLabelExponent property, you're activated, indirectly, the exponent super script font. If you want show the labels in E-notation you should only change the Axis Value Format without change the AxisLabelExponent property. The code below shows you how:
Chart1.Axes.Left.AxisValuesFormat := '#.0 "x10" E+0';
Hoping this helps you.
Thanks in advance
