override text and positioning of marks
WCantrall
Post by WCantrall » Tue Apr 15, 2014 4:55 am
In the vcl and .net versions I have been able to override the behavior of the marks so that I can position a label at the end of lines. How would I start to go about doing that in this version?
Re: override text and positioning of marks
Post by Yeray » Tue Apr 15, 2014 11:27 am
WCantrall wrote:In the vcl and .net versions I have been able to override the behavior of the marks so that I can position a label at the end of lines. How would I start to go about doing that in this version?
I'm not sure to understand what are you exactly trying to achieve. Could you please post some code in delphi/C# and maybe an image showing the resulting so we can better understand what are you exactly trying to do?
WCantrall
Post by WCantrall » Tue Apr 15, 2014 1:26 pm
For instance, this is from the .net tutorial:
OnGetSeriesMark
Use the OnGetSeriesMark event to modify the Mark contents at runtime. The following code varies the MarkText according to the value relative to the last;
[C#] private void line1_GetSeriesMark(Steema.TeeChart.Styles.Series series, Steema.TeeChart.Styles.GetSeriesMarkEventArgs e)
          if(e.ValueIndex > 0)
                if(line1.YValues[e.ValueIndex] > line1.YValues[e.ValueIndex - 1])
                      e.MarkText = e.MarkText + " (Up)";
                 else if(line1.YValues[e.ValueIndex] < line1.YValues[e.ValueIndex - 1])
                         e.MarkText = e.MarkText + " (Down)";
                e.MarkText = e.MarkText + " (No Change)";
WCantrall
Post by WCantrall » Wed Apr 16, 2014 4:16 am
OK, I believe I have more of a grasp of this, as I have tried using Chart.ondraw. What I need now is an example of series calc(index,p) to determine the x and y of the data point.
Thanks!
Post by Yeray » Wed Apr 16, 2014 9:53 am
I'm not sure about what are you exactly trying to do but here you have an example of using the series calc function:
function draw() {
  s = new Tee.Bar().addRandom();
  Chart1.addSeries(s);
  var myFormat = new Tee.Format(Chart1);
  myFormat.gradient.visible=true;
  myFormat.gradient.colors=["white","lime"];
  myFormat.transparency=0.3;
  Chart1.ondraw=function() {
	  var tmpP = new Point(0,0);
	  for (t=0; t<s.count(); t++) {
		s.calc(t, tmpP);
		myFormat.rectangle(tmpP.x-5, tmpP.y, 10, 5);
  Chart1.draw();
function Point(x,y) {
  this.x=x;
  this.y=y;
