* no paths are added to Delphi´s Library Search
* pressing F1 in Delphi leads to no help (theme does not exist)
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Can you add a TChart into a form and run the application or do you receive any error message? If so, which error message/s do you get?* no paths are added to Delphi´s Library Search
This is a known issue as told here.* pressing F1 in Delphi leads to no help (theme does not exist)
narcis wrote:Hi ha28301,
Thanks for your reply.
Then I don't see any problems in no paths being at the Search Path list. TeeChart v7.08 installer already removed TeeChart v4.04 Standard and installed new packages successfully. Is this causing you any problem?
