area series displays blank region
Ed
Post by Ed » Thu Oct 27, 2005 2:34 pm
I am using an TAreaSeries (with MultiArea set to maStacked) and am getting a blank region when I do not add all x values for the series.
Here is an image:
http://www.retireneeds.com/blankareaseries.jpg
What I want to do is have a null value in the series between the positive and negative values--but I do not have values for every item on the X axis, i.e. I am using AddXY(...);
How can I fix this?
Ed Dressel
My code is as follows:
procedure TForm1.UpdateDisplay;
var
I: Integer;
Series1.Clear;
if ComboBox1.ItemIndex = 0 then
//method #1: Works fine
for I := 0 to 9 do // Iterate
Series1.AddXY(I, -I);
Series1.AddNull(9);
Series1.AddXY(I + 10, I);
end
//method #2: Does not work
for I := 0 to 3 do // Iterate
Series1.AddXY(I*3, -I);
Series1.AddNull(9);
Series1.AddXY(I+10, I);
My full project code is here:
http://www.retireneeds.com/blankareaseries.zip
Post by Pep » Wed Nov 02, 2005 11:12 am
Hi Ed,
using the same technique I show you in your other post about stacked area, you could check for Null or 0 points and remove them from the ValueList.
