Hi Steema support,
We have a trouble with drag mark when it doesn't follow the chart during a panning.
Please see more detail in images that we uploaded on your upload page.
There are two images: [Dragmark.jpg] and [Dragmark_Defect.jpg] with user is SiA.
Thanks and best regards.
Drag mark doesn't follow the mouse pointer during a panning
Hi SiA,
For this to work you need to set custom marks positions set to a relative position in the chart and update them when chart is being zoomed or scrolled. You'll find an example here.
Hi SiA,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here and let us know the exact TeeChart version you are using?
You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
Hi Narcis,
With this code, we can set the drag mark following the mouse pointer during panning, zooming and reset drag mark position after panning by clearing all marks position.
procedure TTeeChartExample.UpdateMarks;
var i: Integer;
{Chart1.Draw();
for i:=0 to Chart1.Series[0].Count-1 do
With Chart1.Series[0].Marks.Positions.Position do
Begin
Custom:=True;
LeftTop.X := Chart1.Series[0].CalcXPos(i);
LeftTop.Y := Chart1.Series[0].CalcYPos(i) - 10;
Chart1.Series[0].Marks.Arrow.Visible:=false;
Chart1.Series[0].Repaint;}
Chart1.Series[0].Marks.Positions.Clear;
Chart1.Series[0].Marks.ParentSeries.Repaint;
procedure TTeeChartExample.Chart1Zoom(Sender: TObject);
UpdateMarks;
procedure TTeeChartExample.Chart1Scroll(Sender: TObject);
UpdateMarks;
procedure TTeeChartExample.Chart1UndoZoom(Sender: TObject);
UpdateMarks;
but we don't know how to set a modified drag mark position to new relative position.
Please find the DragMarkTeeChartExample.zip and ExpectedBehavior.doc that we uploaded for your more detail(name : Sia, email: lquocthanh@yahoo.com).
var i: Integer;
{Chart1.Draw();
Begin
Custom:=True;
UpdateMarks;
UpdateMarks;
UpdateMarks;
Hi SiA,
Thanks for the information. In that case you can achieve what you request like this:
I'm going to send you modified project too.
procedure TTeeChartExample.TeeChart1MouseDown(Sender: TObject; Button: TMouseButton;
if (Button = mbRight) then
if(FastLineSeries1.Marks.Visible = false) then
ShowMarks1.Caption := 'Show Marks'
ShowMarks1.Caption := 'Hide Marks';
PopupMenu1.Popup(X+Left,Y+Top);
if (Button = TeeChart1.ScrollMouseButton) then
X0:=X;
Y0:=Y;
X1:=-1;
Y1:=-1;
procedure TTeeChartExample.ShowMarks1Click(Sender: TObject);
FastLineSeries1.Marks.Visible := not FastLineSeries1.Marks.Visible;
var i: Integer;
if ((X1<>-1) and (Y1<>-1)) then
TeeChart1.Draw();
TeeChart1[0].Marks.Arrow.Visible:=true;
for i:=0 to TeeChart1[0].Count-1 do
With TeeChart1[0].Marks.Positions.Position[i] do
Begin
Custom:=True;
LeftTop.X := LeftTop.X + (X1-X0);
LeftTop.Y := LeftTop.Y + (Y1-Y0);
ArrowFrom.X:=LeftTop.X + (Width div 2);
ArrowFrom.Y:=LeftTop.Y + Height;
ArrowTo.X:=TeeChart1[0].CalcXPos(i);
ArrowTo.Y:=TeeChart1[0].CalcYPos(i);
TeeChart1.Series[0].Repaint;
procedure TTeeChartExample.TeeChart1Zoom(Sender: TObject);
//UpdateMarks;
procedure TTeeChartExample.TeeChart1UndoZoom(Sender: TObject);
//UpdateMarks;
procedure TTeeChartExample.TeeChart1Scroll(Sender: TObject);
//UpdateMarks;
procedure TTeeChartExample.TeeChart1MouseUp(Sender: TObject;
Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
X1:=X;
Y1:=Y;
UpdateMarks;
Thanks Narcis,
After modifying a bit:
I could set a modified drag mark position to new relative position.
But there are some unexpected behavior:
-the drag cannot follow mouse pointer during panning
-during panning (because panning defect), length of arrow of drag mark is strength longer and longer.
Hope this will be considered as a fix in future release!
[/code]
var i: Integer;
TeeChart1.Draw();
If Custom = True then
Begin
//Custom:=True;
[/code]
