TeeChart for .NET [25 MAR 2009] RELEASE 3.5.3371.26404/5/6
Post by Christopher » Thu Mar 26, 2009 3:19 pm
Hello!
Full release binary and source code installers are now available from Steema's Customer Download pages accessible via:
http://www.steema.com/downloads/client_access.html
Evaluation version binary installers are also now available.
The release notes for the build can be viewed at:
http://www.steema.com/files/public/teec ... elease.txt
Please note that the "Plug-in license" installer (TeeChartNET3PlugInLic.exe) is no longer built. The TChart/Chart constructors necessary to enable the chart to be plugged into another assembly are now available in the full release version.
Thank you!
http://groups.google.com
http://codenewsfast.com/
Casper JH Erasmus
Post by Casper JH Erasmus » Tue Apr 14, 2009 10:23 am
If I click on the client access link, it takes me to version 1.x and 2.* downloads, not 3.5.
Post by Narcís » Tue Apr 14, 2009 10:30 am
Hi Casper,
At the download area there are installers available for VS2003, VS2005 and VS2008. VS2003 and VS2005 ones are build with 1.1 and 2.0 versions of the .NET Framework respectively. VS2008 installer is also build with 2.0 Framework as it doesn't take advantage of 3.5 Framework features for now.
Casper JH Erasmus
Post by Casper JH Erasmus » Tue Apr 14, 2009 11:07 am
Apologies, I didn't explain correctly.
I'm taken to a page called http://www.steema.com/cgi-bin/teegetR.cgi
On this page on the top it says: Latest Binary version: 6th Dec. 2006 03:47 PM, Build 1.1.2531.28391
I don't see installers for VS2005 or VS2008
Post by Narcís » Tue Apr 14, 2009 11:13 am
Hi Casper,
This means you acessed TeeChart for .NET v1 download page. Even though you may use v1's assembly in VS2005 and VS2008 there are no specific installer for it. Notice that v2 was released in mid-2005, v3 in mid-2007 and next major release is about to be published.
Casper JH Erasmus
Post by Casper JH Erasmus » Tue Apr 14, 2009 11:26 am
Ok then, the latest installer I have is TeeChartNET3VSNET2005.exe which I downloaded on 2008-12-05 build 3.5.3225.32184. Could you please give me the link where I could find build 3.5.3371.26404/5/6.
Not one of the links on page http://www.steema.com.cgi-bin/teegetR.cgi shows me TeeChartNET3VSNET2005.exe.
Post by Narcís » Tue Apr 14, 2009 11:40 am
Hi Casper,
Using TeeChart for .NET v3 keys here:
Should give you access to those versions. If you don't find such keys please contact our Sales Dept. at sales at steema dot com.
Casper JH Erasmus
Post by Casper JH Erasmus » Tue Apr 14, 2009 11:55 am
Aah, apologies then, my mistake. I assume then that I'm logging in with the wrong key and password. Now to find the correct ones...
Thank you Narcis
