Overlapping Labels in Pie Charts
qcrnd
Post by qcrnd » Thu Jul 22, 2010 7:58 am
Hey,
Whenever the pie chart is small and the labels are long there are overlapping in the pie chart texts.
Is there a way to know when labels overlap one another so those can be trimmed?
The pie chart area cannot be enlarged.
Thanks in advance
Elad
Re: Overlapping Labels in Pie Charts
Post by Narcís » Thu Jul 22, 2010 8:02 am
Hi Elad,
Yes, you can do something similar as in the example Pep posted here.
qcrnd
Post by qcrnd » Sun Jul 25, 2010 2:23 pm
Hey Narcís
I have added the method to be called after OnChartAfterDraw and after Resize.
However there are still some problems there, the Chart.Refresh() makes the chart generation take a lot of time, and if I remove it the first draw is not perfect, the resize causes a lot of trouble (in any case).
Does making sure that the pie marks will not overlap each other, something you're planning on solving on later release?
Elad
Post by Narcís » Tue Jul 27, 2010 3:05 pm
Hi Elad,
Can you please attach a simple example project we can run "as-is" to reproduce the problem here and let us know the exact version you are using?
This is on the wish-list to be enhanced for future releases.
qcrnd
Post by qcrnd » Wed Aug 04, 2010 1:20 pm
Hey Narcís
Sorry for the late reply.
I'm using version 3.5.3425.20244
The code I used is the one used in this link: http://www.teechart.net/support/viewtop ... 60&start=0
The problem is the tChart1.Refresh(); found in every loop runs ~(i*j) times
Elad
Post by Yeray » Thu Aug 05, 2010 4:35 pm
Hi Elad,
As Narcis said, we'll try to improve it for future releases.
In the meanwhile I can't think on a workaround more efficient than that one. You can try if calling Refresh after the loop works at your end but I'm not sure if it would work on all the cases.
qcrnd
Post by qcrnd » Sun Aug 08, 2010 1:49 pm
Hi Yerai,
We'll wait for the new release
Elad
