Is there an option in TeeChart fro drawing smooth lines for data series ?
In my application all series points are connected with straight lines.
(I remember splines are doing a great job for drawing smooth lines)
In the TeeChart documentation I went thru all the different line options (fastline, bezier) but I did not come across something about smooth lines.
Some help would be nice.
Antoon Koster
Netherlands
Smooth lines
Hi Antoon,
You can use the smoothing function, creating a line series and setting it's datasource to a smoothing function with another line series as source. Then you can hide the source line series if you wish.
Thanks for your reply. I studied the TeeChart examples, and tried the following, but no smooth lines ....
Any idea what might be wrong ...
My code looks like:
internal void SetLocationSeries()
Steema.TeeChart.Styles.Line line;
int iSeries=0;
for (int iPar=0;iPar<noPars;iPar++)
for (int iTime=0;iTime<noTimes;iTime++)
float[] xValues = new float[noLocs];
float[] yValues = new float[noLocs];
line = new Steema.TeeChart.Styles.Line();
line.CustomVertAxis = customAxis[iPar];
// populating series
line.XValues.DateTime = false;
// line.Marks.Visible = true;
line.Pointer.Visible = true;
line.Pointer.Style = pointerStyles[iPar];
line.Color = lineColors[iSeries];
line.LinePen.Width = 1;
// Smooth lines
smoothLine = new Steema.TeeChart.Styles.Line();
Steema.TeeChart.Functions.Smoothing
smoothing = new Steema.TeeChart.Functions.Smoothing();
smoothing.Interpolate = true;
smoothing.Period = 1;
smoothing.Factor = 10;
smoothLine.Function = smoothing;
smoothLine.DataSource = line;
smoothLine.Visible = true;
tChart1.Series.Add(smoothLine); // add smooth line
for (int iLoc=0;iLoc<noLocs;iLoc++)
smoothLine.Labels.Add(gsLocations[iLoc]);
xValues[iLoc] = iLoc;
yValues[iLoc] = gsSeries[iPar,iLoc,iTime];
tChart1.Series[iSeries].Add(xValues,yValues);
tChart1.Series[iSeries].Title =
gsParameters[iPar] + this.dateTimes[iTime];
tChart1.BackColor = Color.White;
iSeries++;
noSeries = iSeries;
I am using 8 data points per series. That's enough for proper smooting I guess.
Best regards,
Antoon Koster
My code looks like:
int iSeries=0;
// Smooth lines
iSeries++;
noSeries = iSeries;
Best regards,
Antoon Koster
Hi Antoon,
You should use when populating your input series manually.
You should use
smoothLine.CheckDataSource();
Hi Antoon,
have you seen the example of this Function type in the Demo Features project (included with the TeeChart for Net v1 installation ) under :
What's New -> Welcome ! -> New Functions -> Smoothing SpLine ?
It shows how to do this.
Pep Jorge
http://support.steema.com
Yes, I walked thru that example many times, and copied some code from it, but I don't get the smooth spline even after 2 days working ....
I must say, I (and my boss) will be VERY PLEASED if you could send me a complete Visual Studio .NET solution (so a *.sln file) with all the files included for that demo, so that I can check if I get the smooth spline.
Maybe there is something wrong with the installation, In that case I can check that.
My email is: antoon.koster@wldelft.nl
Kind regards,
Antoon Koster
Netherlands
Kind regards,
Antoon Koster
Netherlands
Hi Antoon,
te sources of the Demo Features project are included in the TeeChart for Net installation, you can find them under :
F:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject
Pep Jorge
