Hi Guys,
we're trying to use teechart 3.5.3425.20244 with Windows 7 X64 and Visual Studio 2008 SP1.
we verified all the licensing requirements (licx, registry keys) but still we can't compile and we get a message stating:
"An instance of type 'Steema.TeeChart.Chart' was being created, and a valid license could not be
granted for the type 'Steema.TeeChart.Chart'. Please, contact the manufacturer of the component for more information."
This occurs even in the simplest application.
Idan Bauer
Teechart says it's unlicensed under windows 7
Re: Teechart says it's unlicensed under windows 7
Hi Guys,
Nevermind, we found out the issue it was 64 bit related.
thanks,
Idan
thanks,
Idan
Hi Idan,
We're glad to see you've found it!
I have the same issue - is there a work-around for this?
Also Windows 7 x64
Also Windows 7 x64
Hi SorenBendtsen,
Take a look at the following threads and try to do what is explained on them:
http://www.teechart.net/support/viewtopic.php?t=6711
http://www.teechart.net/support/viewtop ... 96&p=44455
Thanks - I made it work. The registry keys was missing, but I had no luck creating them manually.
I ran the TeeRegV3.exe app. with administrator privileges, and it did the trick.
Hi SorenBendtsen,
I'm glad to hear it!
