I would like to change the color of labels on axis.
I tested two codes below, but both of these did not works.
1)
chart.GetAxis().GetLeft().GetLabels().GetFont().SetColor(RGB(255, 0, 0));
chart.GetAxis().GetLeft().GetLabels().Add(1, "test");
2)
unsigned long idx = chart.GetAxis().GetLeft().GetLabels().Add(1, "test");
chart.GetAxis().GetLeft().GetLabels().GetItem(idx).SetColor(RGB(255, 0, 0));
How can I do it?
Change color of axis label
Re: Change color of axis label
Hi corwl,
Code below works fine for me here. Which TeeChart version are you using?
If problem persists can you please attach a simple example project we can run "as-is" to reproduce the problem here?
m_Chart1.GetAxis().GetLeft().GetLabels().GetFont().SetColor(RGB(255, 0, 0));
Thank you for your reply.
Please check the attached project.
project was produced with VC2003 and TChart version is V8.0 1.
- tchartTest.zip
- (106.31 KiB) Downloaded 662 times
Hi corwl,
In v8, if you are using custom labels, you have to change the label font:
In v2010 changing the axis labels font also applies to the custom labels.
m_chart.GetAxis().GetLeft().GetLabels().GetItem(0).GetFont().SetColor(RGB(255, 0, 0));
Yes it works!
I really appreciate you Yeray.
